I'm replacing my sub and enclosure in my 210, and I was wondering how to install a light ring around the woofer? How do you wire it? Who sells them? Thanks
We offer just about every possible light ring on our on-line store beginning with complete light rings, including acrylic diffuser and LEDs, for $45. You also get the forum discount.
A 10 or 12-inch ring is more. These are 1/2-inch thick (so they are not fragile as you torque down the sub) and have three LEDs per every 2-inches. Very bright and consistent glow.
Wiring is easy. A switched 12-volt source, whether existing or added, plus a light gauge 2-conductor wire (since LEDS pull very little current). In fact, you can run multiple LED fixtures off a single switch and wire. Detailed instructions are included.
David
Earmark Marine
www.earmarkmarine.comEarmark Marine[URL="http://www.earmarkmarine.com"]
www.earmarkmarine.com[/URL]
Any size you want. LED track is rabbeted into the ring so you can still get a good seal on the sub. Wired through the interior of the box with a second set of external terminals.
Contact the on-line store via email for details.
David
Earmark MarineEarmark Marine[URL="http://www.earmarkmarine.com"]
