I recently purchased to underwater LED lights to install on my 2007 SAN TE. In reviewing the Owner's Manual, it appears that the 12Volt Accessory swith on the panel is free and has a 10 amp breaker, which should work perfectly. I went up to the marina today and pulled the panel down and found where the red 12V Accessory Switch wire leaves the harness and heads up bundles with the other wires into the starboard side bulkhead. Obviously, I want this red wire to run all the way to the transom, but my question is does anyone know where this particular wire heads or how far back it goes. I am obviously trying to avoid unnecessarily pulling the side paneling more than I need to find the terminus. Any help would be greatly appreciated.
Also, where should I run the negatives from the LEDs to? Any other ground or should I run it back to the panel and connect to the master ground there?
Thanks,
Thanks,
