Quick Alternator upgrade question
  • TX-Foilhead
    • Mar 2009
    • 351
    • Kingsland TX
    I've been looking through the alternator upgrade threads and pictures and I don't see anything about replacing the 50amp breaker when upgrading to the 100amp alternator. Also seen some debate on Wakeworld about what that breaker is actually protecting, general consensus seems to be the wiring harness to the dash. That would mean the breaker stays and the lack of a larger one with the PCM kit would confirm this. Is this correct?
    Piecing the upgrade together since I have to adapt it somewhat to the Pro Tec system anyway, and that will be changing back to a distributor at some point in the future when it finally gives up. Just trying to make sure I've got all the pieces together before I begin dismantling things this weekend, don't want to have the boat out of commission if the wind stops blowing.
  • bchesley
    • Feb 2006
    • 1252
    • Tyler, Texas
    You actually bypass the breaker all together. You replace the orange wire that is in the factory wiring with a new larger guage wire with a builtin 100 amp circuit. Look at Wakefuns instructions that he has in his album.
    2001 Super Air Nautique
    Python Powered
    100 Amp Alternator
    Dual Batteries
    Many upgrades coming...
    • ers906
      • Feb 2010
      • 921
      • Phoenix AZ
      My breaker occasionally trips for no known cause. Would the upgrade to the alternator and the associated bypass of the breaker have the potential for significant damage? I have checked the contacts for the current alternator, and there is a small amoutn of corrosion, but nothing I would imagine tripping the breaker. Any ideas?
      Eric, Phoenix AZ
      G23 550 hp (finally here)
      2002 Super Air
      • TX-Foilhead
        • Mar 2009
        • 351
        • Kingsland TX
        Cool thanks.
        Breakers get weaker after they have tripped, clean up the wiring and replace the breaker.
        • wake_fun
          • 1330
          • CA
          • 1995 Super Sport
          Check out my pics in my photo album.
          Photo Album
          Ballast Install 1
          Ballast Install 2
          Amp Install
          PPass Install
          Alternator Install
          • TX-Foilhead
            • Mar 2009
            • 351
            • Kingsland TX
            Thanks, the trick was getting off the phone and looking at it on the computer where I could actually read the instruction sheet.
            • TX-Foilhead
              • Mar 2009
              • 351
              • Kingsland TX
              Took a bit longer to get parts collected than I was expecting, but everything is finally here so the project has begun. Question for those who have done this. Did you actually remove the orange wire or just unhook it? I'm thinking it can temporarily stay with the alternator end cut off and capped up and then I'll remove it completely when it comes time for the Protec upgrade. Does
              Anyone see a problem with that? Other than I'm lazy and want the boat back on the water ASAP.
              • bchesley
                • Feb 2006
                • 1252
                • Tyler, Texas
                Mine is still there. I just taped it really well and tucked it out of the way. I did that on two boats with no issues....
                Python Powered
                100 Amp Alternator
                Dual Batteries
                • TX-Foilhead
                  • Mar 2009
                  • 351
                  • Kingsland TX
                  Thanks again, I crimped a cap on the end so I wouldn't be wondering where it went in the future. Everything worked great on the test run. 105 amp alternator and wire was less the $150 DIY couldn't have been easier once I figured out what was going on with the wiring.
                  • Chexi
                    • Feb 2025
                    • 2119
                    • Austin
                    • 2000 SAN
                    $150? Is that a marine/ignition protected alternator?
                    Now
                    2000 SAN
                    Previously
                    1999 Air Nautique
                    1996 Tige Pre-2000
                    • TX-Foilhead
                      • Mar 2009
                      • 351
                      • Kingsland TX
                      Yep, it's a marine 10si. I got it from mycorrectcrraftparts.com (Boat Dr. And his wife Boat Nurse on CCF). I wasn't really sure what it was until I got it, I called because they had the cheapest price I could find on the PCM kit. I talked to him for about 5min because of I was concerned the Pro Tec system might get in the way and he said this is what you need. Got it 2 days later and didn't know what it was until I opened the box.
