Help!! front mount speakers in SAN
  • BrearlyMason
    • Sep 2010
    • 37
    What brand? Are they compression drivers? I also assume you mean you can hear them at riding speed at 80'. That is impressive, and I didn't know there were any other speakers out there that could do this other then HCLD's and the Kicker horn KMT6s. Live and learn.
    I think you will hear most speakers at 80 ft, you might not hear them clearly, but you will hear them. I have four old crappy Pioneer TS-D691R 6"x9" 2-Way 350W speakers. I have two Alpine PDX 4.150 amps powering them. I bridged the amps down to two channels at 300 watts per speaker. You can easily hear them clear across the entire lake.
    • MaineDR
      • May 2015
      • 131
      • Austin, TX
      Not to resurrect an old thread from the dead, but I am trying to do something similar to this on my '00 and can't seem to quite get my screws/nuts to fit inside the outer ring. I am using Polk 651s, so it should be the same install. Is there any trick to the size screw/nut to get these to fit inside the outer ring properly?
      • azeus17
        • Feb 2008
        • 387
        • Grand Rapids, MI
        • 2022 GS22 - Coming in July Previous Boats: 1989 Sport Nautique 2002 SANTE
        I think there was another thread here recently that someone used these plastic speaker rings and removed the original PVC all together. http://​http://www.amazon.com/Univer...r+ring+spacers
        Just slip these behind the vinyl. If I were doing mine again, I would probably go this route.
