I have searched all over and I cant seem to find and descriptions or pictures of this being done on a early 2000's SAN.  Does anyone have any examples of this?
	Tags: None
 There used to be a thread on the old site where it described moving the kick panel, but I cant find it either. I had one under the dash of my 98, but I have the PME box and Perfect pass to do something with now. I have a box built and ready to go in, just need to figure out how to mount all the electronics out of the way and still accessible.2001 Super Air Nautique
 Python Powered
 100 Amp Alternator
 Dual Batteries
 Many upgrades coming...
 Mine is a bit different using the the 13tw5 and an older boat. I moved the PP to side wall where the walk thru would be and then mounted the wall to Tnuts epoxied to the outside of the box. Mine fires to the bow so its completely hidden. The box is held in place by some aluminum angle that is bolted to the sides and mounted to the top of the hump with 5200 to reduce the vibration I put a layer of ensolite foam on the backside of the wall to help keep any vibrations to a minimum as well as added sound deadening foil to a few spots under the area. So far no vibrations at all and the box isnt moving. If it wasn't for the 4 blots that hold the wall, you would never know anything is there until i turn it on I'll probablly end up painting the bolts to blend them to the carpet better. The wall ended up moving about 5in out, you would need to be very familiar with the boat to notice.
 This thread will walk you through the process with lots of pictures.
 http://www.wakeworld.com/MB/Discus/m...tml?11210399521998 Ski Nautique (Red/Silver Cloud), GT-40, Perfect Pass Stargazer 8.0z (Zbox), Acme #422, Tunable Rudder.
