The 'wetbox' seems to be made of hdpe. Any tips on changing the color from yellow to grey? Sand it, prime it, paint it, clear it? What grit paper and what cheap paint will work best? Thanks alot
Most plastics you can paint. But polyethylene is one plastic known for not sticking anything. I use polyethylene when I do not want fiberglass resin, or epoxy, or ant thing else to stick to it. Most paints you could apply to polyethylene, and after the paint is dry, you could just peel the paint off in one big sheet.
I had my local Line-X place spray my sub box. It turned out really good, and I'd highly reccomend that. It was just a little over $100...
