Need help with 2nd voltmeter hookup
  • jhiestand
    • 778
    • Columbus, Ohio
    • 08 Super Air 210
    There's been quite a few threads regarding the problem with the dash gauge not receiving adequate power. I put a second, "house" battery in my SAN a few years back and want a 2nd voltage gauge to measure its status. I picked up a cool looking Summit gauge that will look awesome in the side panel of my boat. Here's the rub.
    The gauge has 3 leads, a RED, BLACK and PURPLE. Since this gauge isn't switched and I don't want it on all the time I plan on using a relay and wiring it to the keypad power. I think I have that part figured out -- hooking it to the +/- of the power outlet on the driver side panel energizes/de-energizes the relay the way I'd like it. The issue tho, is how where do I hook up the RED and BLACK leads? I tried as indicated in the attached diagram hooking to the house battery, no dice. Not only did I get no reading, the leads got really hot really quickly. Not good. Any electrical guru's out there have any advice on what I might be doing wrong?Click image for larger version
    '08 Super Air Nautique 210
  • TurboFan
    • May 2011
    • 47
    • Salt Lake City
    I can probably answer this for you if you can tell me the exact model gauge you purchased.
    • jhiestand
      • 778
      • Columbus, Ohio
      • 08 Super Air 210
      Sum-g2983
      • jhiestand
        • 778
        • Columbus, Ohio
        • 08 Super Air 210
        Call off the dogs! I checked the gauge connected directly to the battery and it checked out, so I went back to the relay. It must've taken a beating the first time I tried it hooked up incorrectly. Picked up a new relay and SHAZAM! Ran the whole assembly hooked up for a while and all seems well.
        • jhiestand
          • 778
          • Columbus, Ohio
          • 08 Super Air 210
          Got everything put back together and working like a charm. The new gauge also confirmed what I already knew -- that the voltage reading I'm getting on the dash gauge likely isn't correct. Well, it's probably correct but the dash probably isn't getting enough power. I guess I'll need to take another look into that.
          Front mounted Polks sound great and I'm stoked about the new gauge!
