Need Sub recommendations - 10"
  • Chris4x4Gill2
    • Jul 2008
    • 406
    • Smith Lake, AL
    • '89 Ski Nautique 2001
    I need to replace the sub in my boat so I'm looking for suggestions that will fit well within my current setup.
    The boat is an 89 SN, the sub is mounted under the closed bow firing towards the stern of the boat. Box is a 10" slot ported 14x16x12 (3/4thick) so I figure 1.1cuft including the ported area. Will be powered by a Clarion APX480M - bridged to 2 channels. Amp specs are 640W Peak, 80Wx4 continuos @ 4ohms, 115Wx4 @ 2ohms.
    All I am looking to repalce is the sub and use my current box / amp setup.
  • tazz3069
    • Apr 2009
    • 100
    • Nevada
    Boston Acoustic G3 Sub
    • Chris4x4Gill2
      • Jul 2008
      • 406
      • Smith Lake, AL
      Is this the one you are talking about?
      http://www.crutchfield.com/p_065G310...ype%7cFFPorted
      Its listed as needing 1.3 cuft of airspace, slightly more than the 1.1 that Ihave. Will this matter? It also comes in either single or dual voice coil models, which is better for my needs? what is the difference?
      • Chris4x4Gill2
        • Jul 2008
        • 406
        • Smith Lake, AL
        also, would the G110 or G220 be better choices? They are listed at requiring less RMS power. My amp falls into the range of the listed requirement for the G3, but its on the low side. I would be closer to the high side on the G1, more to the middle on the G2.
        • tazz3069
          • Apr 2009
          • 100
          • Nevada
          I am not familiar with the other two subs. I have the G3 in my boat. I also have the sub enclosure from www.audioformz.com with a kicker 700.5 marine amp pushing it. All I can say is that the bass is very tight and sounds awesome.
          • Chris4x4Gill2
            • Jul 2008
            • 406
            • Smith Lake, AL
            do you know the CF of your enclosure? is it ported or sealed?
            • tazz3069
              • Apr 2009
              • 100
              • Nevada
              Here is the Link of the Sub It is a sealed enclosure
              http://www.audioformz.com/monoglass.asp
              • 74green
                • Nov 2009
                • 281
                • Canyon Lake, Texas
                • 2001 Air Nautique
                I have been very pleased with my Kicker dual voice coil 10" sub. Its a CVR104.
                Current: 2001 Air Nautique GT-40
                • Chris4x4Gill2
                  • Jul 2008
                  • 406
                  • Smith Lake, AL
                  well after doing alot of reading and research, I have narrowed it down to a single voice coil sub with a max rms of 300 watts. This is because I intend to use two channels of the sub for the amp and two for the cabin speakers. Using two channels bridged for the sub should give me 230w RMS. I am looking at JL right now, the 10W0v2-4 and the 10W1v2-4. The BA G3 is still in the mix as well but I think im leaning towards the cheaper JL.
                  • TX-Foilhead
                    • Mar 2009
                    • 351
                    • Kingsland TX
                    Using a ported box it will sound best if you find a sub that matches the box first then the amp.
                    • Chris4x4Gill2
                      • Jul 2008
                      • 406
                      • Smith Lake, AL
                      All three I listed above match the cuft. Of the box
                      • lucky7t
                        • Mar 2011
                        • 1306
                        • Oklahoma
                        • 2015 SANTE
                        I have a kicker 10 CVX10 with a Digital Designs Mono Block at 1 ohms and a plastic marine ported enclosure that will blow the access door open if need be. My 2 cents is buy a good sub,box and amp. I installed a week ago and cant believe the 10 hits so hard. I agree a ported box will help alot. Heck even got to keep my cooler
                        Current Correct Craft Boat
                        Correct Craft Boats Owned
                        • Cam003
                          • Jun 2007
                          • 209
                          • Petaluma, CA.
                          • 2004 SANTE
                          i have had jl W0s, W3s, and W6s. spend the money and get the W6 if you can power it. it may be the best SOUNDING and POUNDING sub i have evr heard.
                          Our Setup
                          • Chris4x4Gill2
                            • Jul 2008
                            • 406
                            • Smith Lake, AL
                            I went with the JL 10W1v2-4. Got it onstalled this weekend and am very happy with the sound. Big improvement over the old wore out sub I had in there.
