Need new batteries
  • EarmarkMarine
    • Mar 2008
    • 699
    • Dallas, TX
    'dp' denotes dual purpose which means thinner, lighter plates and less capacity for deeper cycles as a percentage before battery degradation begins. A true consumer level deep cycle battery will tolerate a repetitive 50 percent discharge. A full charge is 12.7 volts. A 50 percent charge is 12.0 volts. Ever check your true voltage after a period at rest and before starting the engine?
    David
    Earmark Marine
    www.earmarkmarine.com[/URL]
    • gride
      • Jun 2007
      • 1441
      • War Eagle
      • 05' 210 team
      Would it be smarter to get a cranking battery and a deep cycle? I do have a 1,2, all perk switch and I'll be redoing my power and ground since I'm moving to a two battery system.
      • EarmarkMarine
        • Mar 2008
        • 699
        • Dallas, TX
        gride,
        We have already addressed that issue in some detail. If you don't mind go ahead and re-read the thread and you will see my thoughts on that one.
        David
        Earmark Marine
        • gride
          • Jun 2007
          • 1441
          • War Eagle
          • 05' 210 team
          So two group 29's with a perko 1,2,all switch? I was confused over whether you meant a 24 and 29 or what not.
          • gride
            • Jun 2007
            • 1441
            • War Eagle
            • 05' 210 team
            i can get a deka group 27 flooded for 99$, or a group 29 agm for 169, and agm 27 for 139. that's the retail price, but my family business gets a discount. with the stock alternator what would ya'll choose? im going with 2 deep cycles.
