Syn 6 amp draw
  • gride
    • Jun 2007
    • 1441
    • War Eagle
    • 05' 210 team
    Syn 6 amp draw
    I looked in the manual and didn't see it. My guess as 120amps?
  • EarmarkMarine
    • Mar 2008
    • 699
    • Dallas, TX
    Fusing is for protection if something catastrophic happens. If you load the Syn6 down to its lowest permissable impedance and push it to full output then I would expect no more than 70 amps of continuous/average draw given the transient nature of most music. Fusing is slow blow so your draw can exceed the fusing for a short duration.
    David
    Earmark Marine
    www.earmarkmarine.com[/URL]
    • EarmarkMarine
      • Mar 2008
      • 699
      • Dallas, TX
      If your concern is strictly protection, rather than normal draw for calculating amp/hours, then a master fuse or breaker should be equal to the collective fusing found in the end cap of the SYN6 chassis.
      David
      Earmark Marine
      • gride
        • Jun 2007
        • 1441
        • War Eagle
        • 05' 210 team
        I'm redoing my system. 1/0 power/ground with a stinger spd5203 fuse holder. I was trying to figure out fuse size. Amp 1 is 46amps,amp 2 is 28amps.
