Guys, I figured this was the best place to post this question due to its electrical nature.
Boat is a 2003 SANTE which is stock (stock tower and boat speakers, 2 clarion marine amps, dual batteries with stock switch). Engine is the excal 343 with stock alternator. Batteries are Deka and fairly new.
My issue: this spring I replaced my stock ballast system with (3) Johnson Ultra Ballast pumps. I wired them to the stock keypad using automotive style relays to operate the pumps, this system works great with one exception. While the boat is running, I can turn all of the pumps on and fill the ballast system, no issues there. The problem is when I go to turn the pumps off (one by one), the voltage to the dashboard varies and the dashboard cuts out for a half second, then kicks back on. The problem is it cuts off the perfect pass and speedo as well, causing the boat speed to surge and the speedo to not work until the boat is shut off, and then re-started.
I figure each pumps draws about 13-15A according to page 7 of the pump manual: http://www.johnson-pump.com/jpmarine...410_F4B-11.pdf
I believe what is happening is when I shut the pumps off, the voltage to the dash jumps to a level that is out of range of the dash components. Does this sound logical? What is the most economical way to solve this issue? I've read that increasing wire size could help, installing a capacitor, or upgrading the alternator could all help. I don't want to chase my tail on this.
I'm open to suggestions. Can anyone recommend a capacitor if that is the way to go? Would I need one for each battery?
Thanks guys!
Thanks guys!
