Speakers quit working
  • TRRJr
    • May 2011
    • 5
    • California, MD
    • 2009 Air Nautique 236
    I have an '09 Air Nautique 236 and over the winter had a ballast tanks and wet sounds tower speakers installed. Prioir to these installations all my other speakers worked great. When I picked the boat up (dealer is about 2 hours away) they told me the amp for the subwoofer and boat speakers had blown. They drop shipped one to me and I hooked it up. It worked good for about 2 weeks and then the amp was showing that it was in "protected" mode. I went and got a new amp and put it in and can get some bass out of the boat speakers and sub, but no high range sound. I still get sound out of my wet sounds speakers. I have no idea what is causing this and no idea where to start looking. Any thoughts?
  • nms1991
    • 477
    Sounds like a bad speaker is blowing the amp. normally the factory system has all the speakers in the area behind the windshield and the sub working off of the amp.
    • TRRJr
      • May 2011
      • 5
      • California, MD
      Is there any way to isloate which speaker it might be?
      • Cam003
        • Jun 2007
        • 209
        • Petaluma, CA.
        • 2004 SANTE
        locate the factory speaker wiring, and undo the rediculous splice job CC did and connect them one at a time. you will know which one is bad.
        Our Setup
        • AirTool
          • 4049
          • Katy, Texas
          You should be able to test each with an ohm meter....maybe while connected to the amp.
