The wiring diragram does not spell it out very well and i am not very tech savy. so I am looking for some lay out to wire this up I have run the power and ground then i am lost with the rca cables and other wires. any help would be great. P.S. It is a SN206 with factory head unit. Thanks
You should be able to just simply run an rca patch cable to your amp.If both rca cables are used already then you will need 2 y connectors l
Heres link to install manual
http://www.clarion.com/us/en/support...ll%29,0.pdf%27
Heres link to owners manual
http://www.clarion.com/us/en/support...al%29,0.pdf%27
Good luckCurrent Correct Craft Boat
Correct Craft Boats Owned
Thanks for the links.
I got it hooked up and it sounds great but the bow speakers now don't work the amp is a JL Audio JX 360x4, I hooked both RCA cables up one to the front and one to the rear and I am not sure where the bow speaker wires are and where to hook them up to? there are speaker hook ups that are not RCA style can I find the wires for the bow speakers and just hook them to that?
Thanks for your help.
Yes your front speakers are not amplified from the factory. You will need to run those to your amp.
I don't remember what color they were in my older boat but do a search for front speaker wire color and the year of your nautique.Current Correct Craft Boat
what year is your boat?
I see its a SN206 with a CMD4 but what year. Maybe i can help with speaker wire colors for youCurrent Correct Craft Boat
