05 SAN, XMD3 Speaker issues
  • Sell
    • Jan 2010
    • 58
    Hi,
    I have an 05 210 with the stock Clarion stereo.
    The cabin speakers have suddenly given up. The bow speakers are working fine.
    Does anyone have a wiring diagram?
    Or any ideas on tests to try before I start to chop up the loom to test each speaker line individually?
    Thanks,
    Ken
  • Quinner
    • 2246
    • Correct Crafts
    Do you also have the factory sub and is it working? If you have a sub and amp, Bow speakers are wired direct to deck, other (4) cabin speakers and sub powered thru the amp.
    Make sure your balance/fade is correct also.
    • Sell
      • Jan 2010
      • 58
      Yes factory amp & sub.
      The balance & fade on head unit are set to 0, so it's not that
      Actually, I don't think the sub was working correctly either - so i'm going to look at the amp settings now.
      Thanks mate - I have no idea about stereos.
      • Sell
        • Jan 2010
        • 58
        Ok definitely no sound from sub or cabin speakers. Light is on on amp but nothing I did made any difference.
        How do I check the amp?
        • Quinner
          • 2246
          • Correct Crafts
          I would call Clarion (assuming it is a factory clarion amp), not sure myself, sorry. If the amp is toast you may want to consider adding a 2nd one when you replace, 1 to push the sub and the other to push the speakers. Maybe one of the smart stereo guys like Mikeski or Earmark will chime in also.
          • Cam003
            • Jun 2007
            • 209
            • Petaluma, CA.
            • 2004 SANTE
            if you have a headphone jack to rca cable, you can plug an ipod straight into the amp
            Our Setup
            • Sell
              • Jan 2010
              • 58
              Thanks Cam, it seems that the amp is toast unfortunately.
              I'll pull it out & look for a new one.
              Thanks for all your help.
              • obd666
                • Feb 2010
                • 793
                • Bostian Heights, NC
                • 03 SANTE
                if you have a light on the amp but no sound from the speakers, check that you have 12V at the amp just to be sure the inline fuse isn't starting to go. also, make sure light that is on isn't the "protection" light ...
                2003 SANTE - "OG 210"
                • Sell
                  • Jan 2010
                  • 58
                  I'll check voltage tonight, what is the 'protection' light?
                  The light that is on appears to be a blue LED.
                  • obd666
                    • Feb 2010
                    • 793
                    • 03 SANTE
                    some amps have a protection light to indicate that it has gone into "protection mode", which could indicate the amp is cooked, overheated, etc. - in this case it could be because of low voltage, and why you would test to see if you have good voltage at the amp. have seen dual element/time delay fuses go bad but still trickle enough voltage thru to illuminate a light on the amp, causing you to overlook a bad inline fuse
                    • Jwake
                      • Aug 2012
                      • 17
                      • Land O Lakes Fl
                      • 2005 210 SANTE
                      Sell, did you figure this out? I have a 05 SANTE same issues. light on amp. no sound to rear speakers just bow???frustrating
                      • C.A.
                        • May 2011
                        • 32
                        • Umatilla, FL
                        • 2015 G23 Coastal 450
                        I have the stock amp that I took out of my boat if someone wants it.....
                        • tvaleri
                          • Aug 2012
                          • 52
                          • Fresno, CA
                          • 2014 Super Air Nautique 210 Team Edition 2007 Super Air Nautique 220 Team Edition - Sold
                          I had the exact same problem in my '07 SAN. It turned out I had a blown amp. Ultimately I replaced the amp with a cheap Memphis 4-channel amp, rewired the cabin speakers and bow speakers to operate off the new amp, used the two channel amp to run my tower speakers, and added a second sub with a dedicated amp to run it and the factory sub. I'm happy with the results.
                          • jkallen21
                            • Jan 2013
                            • 399
                            • United States
                            • 2006 Super Air 220
                            I'd be interested - thanks.
