So here is my question, does anyone make an usb bluetooth adapter to convert my factory clarion receiver to stream music wirelessly through the usb port?
I use a bluetooth Music Receiver adapter to stream music from my iphone through my factory stereo. Simple as plugging into the auxiliary input port and then plug into USD port for power and this thing works great. Never a problem. Just need to turn it on at the start of each session. Ordered it off Amazon with the attached link.
http://www.amazon.com/Miccus-BluBrid...ref=pd_sim_e_2
Hope this helps.
Clarion BLT370
http://www.clarion.com/us/en/product...392722474.html___________________
2011 SANTE 230
2008 SV211 Crossover Air Nautique
2005 Malibu Sportster LX (sold)
The boat is at the dealer for another week until we pick it up for the summer.
Which of these will I need? I remember seeing a USB for power, but not sure if there is a mini jack(headphone) jack on the head unit.
OR... Should I order the model with RCA inputs?(is there an open set of inputs on the back of my stock Clarion head unit?)2013 SAN G23 450
Correct pic for mini jack input.
Originally posted by higginalske5 View Post[ATTACH=CONFIG]22324[/ATTACH][ATTACH=CONFIG]22325[/ATTACH] The boat is at the dealer for another week until we pick it up for the summer.
Originally posted by higginalske5 View PostYes. I understand that the USB is for power only.
My question is: What output source is available on the stock Clarion head unit?
RCA?
minijack?
input source you mean?
There are two sets of RCA AUX inputs on the back of the CMD6. One of those is presumably used to go to the aux port on the dash.
manual here: http://a248.e.akamai.net/pix.crutchf...20/020CMD6.PDF
I just installed the miccus, along with one of these in my boat this weekend: http://www.isimplesolutions.com/char...ltDM-IS43.aspx
The miccus is left plugged into usb, and zip tied up under the dash where nobody can see anything. In preliminary testing it works perfectly. Comes back on automatically with power and the phone easily recognizes it. I get no noise from the engine running at all (I was careful to use the same power source for deck, eq, hse revolution and the hubvolt).
Originally posted by shawndoggy View PostI just installed the miccus, along with one of these in my boat this weekend: http://www.isimplesolutions.com/char...ltDM-IS43.aspx
The miccus is left plugged into usb, and zip tied up under the dash where nobody can see anything. In preliminary testing it works perfectly. Comes back on automatically with power and the phone easily recognizes it. I get no noise from the engine running at all (I was careful to use the same power source for deck, eq, hse revolution and the hubvolt).'18 SAN 210 Reef Blue/Admiral Blue Metal Flake
'12 SAN 210 TE Black/Masters Blue
'09 SAN 210 TE Black/Fury Red
'08 Air 216 TE
'02 Air 216
'98 Sport Nautique
'89 MC Prostar 190
Originally posted by jharris View PostOrdered it off Amazon with the attached link.
Hope this helps.
Success: easy install and sync to my iPhone.
Fail: pops and crackling on boat ignition and cutoff. Crackling intermittently while underway.
I tried the power port and 3.5 mm jack by the driver side armrest and the RCA input and power port by the head unit. Same result.
its going back to AmAzon.com
i am going to give this a try. No need for a power source. It's powered by the USB and receives through a std. Apple 30-pin cord.
http://www.target.com/p/interworks-bluetooth-wireless-receiver-8108404/-/A-14505207#prodSlot=large_1_6&term=Bluetooth2013 SAN G23 450
This is what I use and love it. Stays connected, no static, works great. Will not stay connected is driving device leaves the boat. Hope this helps someone.
http://www.crutchfield.com/p_822BTRE...rine+bluetooth2005 226 TEAM
