2011 200 with 6 polk speakers/amp
  • lfryer
    • Aug 2011
    • 8
    • australia
    • 2011 ski nautique 200 ob
    I have a 2011 ski nautique 200 ob with factory cdm1 hu and 6 Polk mm651 speaks.
    I bought a Polk 4000.4 and not sure best way to configure,I'm thinking of wiring bow speakers to hu and rest to cockpit amp.
    The cdm1 only has 1 RCA output so guess ill run this to REAR input of amp and set to 2channel and fade bow speaks as clipping will start way earlier than cockpit speaks.
    Anyone else have this standard setup?
    • 2908
    Series 3 left speakers to bridged front amp channels, series 3 right speakers to bridged rear amp channels will give you design load to the amp and balanced power to all speakers. This will give you about 85 watts to each speaker. You might want to enable the high pass filter at about 60hz to help the speakers produce more sound in the range where they work best. I don't know of any way to wire these 2.7 ohm speakers to an amp that wants to see between 2-4 ohms to each channel. The configuration I described yields a 4 ohm load on each one of the amplifier's 4 channels.
    • lfryer
      • Aug 2011
      • 8
      • australia
      Thanks mikeski
      I presume you mean to run three speaker possitive and negative wires to front channel outlets of amp and in the bridged positions of ch1 and ch2
      • lfryer
        • Aug 2011
        • 8
        • australia
        Duh! I get it mikeski,I was thinkin parallel for a second.
        You mean to make speakers hold hands and the end hands join to the bridged channels.
        Thanks mate ill give it a go!
