Battery Chargers
  • Quick VR-4
    • Aug 2011
    • 141
    • Tennessee
    • 2012 SANTE 210
    Sounds like the OP is running into a situation I had when I installed my 2-bank charger which David also helped me out with. My cables would not reach both batteries since one was port and the other was starboard. I mounted my charger in the starboard locker so that it would reach my starting battery. I then lengthened my cables to reach the port side charger. I went with a Guest 2-bank and their tech support said that was fine...just keep wire gauge the same and keep fuses close to battery. I also used Dave's suggestion in using solder/shrink wrap method for the connections. Some others commented on my thread that other companies would void warranty, but Guest said it was fine. Even mounting the charger right in the middle, it would still not reach as mine only had 4ft cables so I had to lengthen.
    2005 SANTE 210 - Sold
    2012 SANTE 210 - Current
    • axeman
      • Apr 2012
      • 387
      • Dallas, TX
      • 2016 Super Air Nautique 230
      How much more did you have to lengthen? The ProMariner ProSport 20 Gen 2 Plus has 6ft long cables.
      • Quick VR-4
        • Aug 2011
        • 141
        • Tennessee
        • 2012 SANTE 210
        I went ahead and lengthened the port side another 4-5 ft. so I could route and zip tie so it was hidden from view. The tech guy I spoke with said that anything under 10 ft. would not require any additional modifications or larger gauge wire.
        • Denman210
          • Jan 2015
          • 20
          • Rowlett Texas
          Are the 12'volt plug in outlets 15 amp or 20 amp on a 2013 210? Trying to make sure my Ronix pump has the correct amps.
