Sounds like the OP is running into a situation I had when I installed my 2-bank charger which David also helped me out with. My cables would not reach both batteries since one was port and the other was starboard. I mounted my charger in the starboard locker so that it would reach my starting battery. I then lengthened my cables to reach the port side charger. I went with a Guest 2-bank and their tech support said that was fine...just keep wire gauge the same and keep fuses close to battery. I also used Dave's suggestion in using solder/shrink wrap method for the connections. Some others commented on my thread that other companies would void warranty, but Guest said it was fine. Even mounting the charger right in the middle, it would still not reach as mine only had 4ft cables so I had to lengthen.
Originally posted by axeman View PostHow much more did you have to lengthen? The ProMariner ProSport 20 Gen 2 Plus has 6ft long cables.2005 SANTE 210 - Sold
2012 SANTE 210 - Current
