For those of you with the Rev 10 or Pro 485 what amp do you have experience with or do you recommend? I have the Pro 485 and are currently way under powered with the Polk amp that is running them. There is also a 10" WS sub hooked to the Polk amp as well. I recently purchased the boat and am now ready to sort the stereo system out. Here is what I can tell you about it:
Stock Clarion Head unit and remote
Tower speakers" WS Pro 485 (2)
Boat Speakers: stock Polk speakers (6)
Sub: WS 10" free air
Amps: 1 Polk stock (running tower and sub) and 1 Concept 1003
running the boat??
EQ: WS 420
I feel that I have some good stuff to start out with but the amps are definitely not cutting it. I would like to either purchase a new amp for the 485s and use one of the existing amps for the sub and then run the boat off of the concept but not sure if the stock Polk amp will run the WS sub effectively.
I know I have left some info off on the amps and hope to get back to the boat in a couple of week to see exactly what needs to be sorted out.
Thanks for the input.
EQ: WS 420
