Upgrading a 2008 210 SANTE
I am reading through many posts regarding adding additional batteries, using an ACR, or a pro-mariner sport 2 and 3 bank charger. There is even talk of golf-cart batteries doing the trick. I have the factory battery setup with the obvious battery selector (battery1,battery2,both). I plan on running 3 amps and for the most part running the system for multiple hours without having the boat running. As I read I see one battery is for starting the boat and the other is assigned to the accessories or in most cases the stereo load. Is there an issue with having the selector at "both"
Can someone suggest a simple solution to powering a 3 amp system? All help is appreciated.
