I have a 2010 230 with the c5 cargo rack and would like to replace 2 if not both pair polks with something. There is not a lot of space where the top 2 polks are mounted but plenty room below. What would be the best set up. Thanks
Originally posted by dgreene View PostI have a 2010 230 with the c5 cargo rack and would like to replace 2 if not both pair polks with something. There is not a lot of space where the top 2 polks are mounted but plenty room below. What would be the best set up. Thanks
Also if you do go the Wetsounds route look in the group buy section and there is a contact i posted and he can setup you up with a discount.
Hope this helps
Dave
1 pair of Rev10s on a quality 400w ea x2 class D amp . Amp fed well with 420sq or ZLD to get pre-amp volts up.
this setup will exceed expectations for 95% of folks and you will be well under $2k for the setup.2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
