Installing Millenia Bluetooth Adaptor Questions
  • spunkie202
    • Feb 2013
    • 50
    • orlando
    • 2006 210
    Guys I wanted to install the bluetooth adaptor to my clarion unit. I have an original 2006 210 SAN and I was wondering how many rca inputs I have in the back of the head unit (CMDA 4 or CMDA 5?) or if should just plug it into the rca jacks in the glove box that I usually plug my wired cable into.
    Next question is where are you guys splicing into the power? the 12 v AC adaptor? or any other place to power and ground the unit.
    Here is the unit
    http://www.crutchfield.com/S-4VKma3B...MIL-BTREC.html
    thanks in advance
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    That generation Clarion head-unit has only one set of RCA AUX inputs. They have red leads. The other 3 sets, gray, black and purple are outputs. You can use a couple of Y cable so you dont lose use of the glovebox AUX.
    • spunkie202
      • Feb 2013
      • 50
      • orlando
      • 2006 210
      MLA im not too savvy when it comes to this. Could you be a little more specific on the Y cable or show me a link to one so I know exactly what im doing and where I am plugging them in??
      thanks
      • spunkie202
        • Feb 2013
        • 50
        • orlando
        • 2006 210
        Is the Y cable a 1 male RCA connecting to 2 females? If that is the case, do I need 2 of these Y cables? Thanks in advance MLA
        • spunkie202
          • Feb 2013
          • 50
          • orlando
          • 2006 210
          Also anyone know what I can wire this thing to for power? all help is greatly appreciated as I am a novice.
          • MLA
            • Dec 2009
            • 1312
            The B+ and B- for your BT should share with the rest of the audio gear. I would wire it in with the head-unit's black B- and yellow B+ if its wired through a battery switch. if the yellow is wired directly to the battery, then use the red switched B+.
            RCA Y cables come in 1F x 2M and 1M x 2F configurations and usually come as a pair. Since your BT has 2 male connectors, I would get the 1F x 2M
            • spunkie202
              • Feb 2013
              • 50
              • orlando
              • 2006 210
              MLA thanks for the help! I installed it and it is working great.
              • scottb7
                • Aug 2011
                • 2198
                • Carson City, Nevada
                That is pretty cool. I think I NEED one.
                • spunkie202
                  • Feb 2013
                  • 50
                  • orlando
                  • 2006 210
                  If you are looking to keep your RCA glove box inputs too I bought these y cable splitters off crutch field to split the RCA input
                  http://www.crutchfield.com/p_119ILJR...Y-adapter.html
