Arc Audio 600.2 question
  • Paxdad
    • Mar 2013
    • 775
    • Cumming, GA
    • 2008 210 SANTE
    My new Arc Audio 600.2 appears to have dropped a channel as only one of my two WS Pro 485 has sound out of it. When I switch the RCA Left and Right cables I get sound out of the opposite speaker so I know it is not the speaker. All fuses are good on the amp. Could this be WS 420 issue or is it likely the amp? The amp is still under warranty but doubt the 420 is.
    2008 210 SANTE
  • EarmarkMarine
    • Mar 2008
    • 699
    • Dallas, TX
    You have confirmed that everything is operational after the RCAs. Use the same method to eliminate each component upstream, starting with the RCA cable and then the EQ. Since the same channel works in the boat the issue is not upstream from the EQ. Since the EQ has both in-boat and tower outputs for that same channel, it's an easy swap to isolate each EQ output.
    David
    www.earmarkmarine.com[/URL]
    • Paxdad
      • Mar 2013
      • 775
      • Cumming, GA
      • 2008 210 SANTE
      Just to close the thread out it was the rca cable from WS420 to amp.
      2008 210 SANTE
