Clarion AMP keeps going out
  • Turp
    • Mar 2005
    • 12
    • Cleveland
    New Clarion AMP installed by dealer on SV-211 went bad when radio was turned on. Replaced with 2nd AMP, worked 4 days and went out. Power is hot to the AMP. No blown fuses. No power indication on AMP. What gives?
  • FatBoy
    • Mar 2004
    • 756
    • Eastern North Carolina
    RE: Clarion AMP keeps going out
    Is your ohm load right on the amp? The Clarion amp is 4 ohm, if someone wired your speakers to a 2ohm load it could be the prob.
    Life is Short, Live it!
    http://www.teamcarolina.us/index.htm
    • Turp
      • Mar 2005
      • 12
      • Cleveland
      Don't know for sure. Will check the settings tomorrow. Thanks
      • OldFart
        • Jun 2004
        • 401
        • South of North & East of West
        CHECK that drain hole for cooler, if above amp, has a hose going to the bilge; vs dripping on amp.
        \"The voices aren\'t real...but they have some good ideas.\"
        • Turp
          • Mar 2005
          • 12
          • Cleveland
          AMP
          Yes, the AMP is located right under a vent on the port side. There is a vent
          on the SV-211 right under the windshield and under inspection after a mod.
          rain, the AMP is wet. Will this short the AMP out?
          • G-man
            • Jun 2004
            • 428
            • Allen, Texas
            RE: AMP
            I beleive you found your problem, water and electronics don't mix, I don't care what the label says. I am surprised a dealer mounted it where water could get it so easily.
            Current
            2003 SkiNautique 206 LE Yellow - Black - Silver Cloud
            Previous Fleet
            2006 Ski Nautique 196 SE Titanium - Black- Silver Cloud
            2004 Ski Nautique 206 LE Red - Black - Silver Cloud
            1993 Mastercraft Stars & Stripes 190 Red
            • gotwake
              • 304
              • Mundelein, Il
              It's probably not water, but heat. If your amp keeps going out and in a short while comes back on, I doubt that it's a short caused by water. (Fuse blown?) The Clarion amp, as most amps, has a protection circuit that will shut the amp off when it gets too hot. To test, pull the front cushion and run your boat as you normally would. This will allow more air to reach the amp and should help it to cool.
              The person who said \"Money can\'t buy happiness\" never rode behind an \"OLD\" 210.
              • gotwake
                • 304
                • Mundelein, Il
                Sorry - reread your post, it sounds like it is dead and doesn't come back on.
