Roswell underwater LED's?
  • thejean
    • Aug 2017
    • 364
    • Calgary, AB
    #46
    Originally posted by Millerda68 View Post
    Attwood Marine (Factory lights) -
    Lightarmor - 6 HP - 3200 lumens - $263
    6 HPX - 5000 lumens $370
    Do our boats come stock with the HP or the HPX?
    • blueroom
      • Mar 2017
      • 623
      • Northwest
      • G23
      #47
      Pretty sure factory are the Attwood HP's - 3200 Lumens.
      I have them from the factory, and I would never run these as a choice. I have replaced one under warranty, and both the remaining stock one and the brand-new replacement are full of water. I talked to Attwood and their response is that it is likely "condensation" from running them while moving - something they say you can't do. I don't think condensation would pool water inside the lens. : )
      Probably just a matter of time before they blow again. I was on another '16 G23 the other day and it had the Circuit Fault warning on the underwater lights as well. Pretty much a telltale sign that one of them has shorted out due to water intrusion.
      I would go for the Roswells for sure in a new or retrofit situation. Not the brightest light you can buy, but solidly built.
      • thejean
        • Aug 2017
        • 364
        • Calgary, AB
        #48
        I want to try the liquid lumens ones but the location of the bolt holes for the stock lights makes it difficult to cover them with round lights.
