HAs anyone installed or currently using the Roswell underwater lights? I know Zach favors the Shadow Caster however I was curious if anyone was using the Roswell? I know most say go with the blue however I was thinking about matching the boats red exterior. Thoughts?
- Mar 2002
- 16385
- Lake Norman
- Mooresville, NC
I'll have the Roswells in about two weeks on the PN boat! Can't wait! I'll give a full write-up once I have the boat.
Current Boats —> 2025 Super Air Nautique G23 -- 2001 Ski Nautique -- 2000 Nautique Super Sport PYTHON -- 2000 Nautique Super Sport -- 1999 Ski Nautique PYTHON -- 1998 Ski Nautique -- 1985 Sea Nautique 2700 (Twin-Engine, 1 of 13) -- 1981 Fish Nautique (Twin-Engine, 1 of 4) -- 1980 Fish Nautique (Twin-Engine, 1 of 4)
Former Boats —> 2024 Super Air Nautique G23 PARAGON -- 2023 Super Air Nautique G23 -- 2022 Super Air Nautique G23 PARAGON -- 2021 Super Air Nautique G23 -- 2021 Super Air Nautique G23 -- 2020 Super Air Nautique G23 -- 2019 Super Air Nautique G23 -- 2018 Super Air Nautique G23-- 2018 SAN 210 TE -- 2017 Super Air Nautique G23 -- 2016 Super Air Nautique G23 -- 2015 Super Air Nautique G23 -- 2014 Super Air Nautique G23 -- 2014 Super Air Nautique 230 Team Edition — 2013 Super Air Nautique G23 — 2012 Super Air Nautique 210 Team Edition — 2011 Super Air Nautique 210 Team Edition — 2010 Super Air Nautique 210 Team Edition — 2008 Super Air Nautique 230 Team Edition — 2007 Air Nautique 236 Team Edition -- 2007 Air Nautique SV-211 -- 2005 SV-211 -- 2003 Super Air Nautique 210 Team Edition -- 2003 Air Nautique 226 -- 2003 Sport Nautique 216 -- 2003 Ski Nautique 196 -- 2003 Ski Nautique 196-- 2002 Ski Nautique -- 2001 Sport Nautique -- 2001 Ski Nautique -- 2000 Sport Nautique -- 1999 Ski Nautique Open Bow -- 1999 Air Tique 176 -- 1998 Ski Nautique -- 1998 Ski Nautique -- 1997 Ski Nautique -- 1997 Ski Nautique -- 1996 Ski Nautique Open Bow -- 1994 Ski Nautique -- 1993 Barefoot Nautique -- 1983 Fish Nautique (TWIN ENGINE, 1 of 4) -- 1981 Fish Nautique (SINGLE ENGINE)
NautiqueParts.com - Phoenix Trailers - SkiSafe - PCM Marine Engines - PerfectPass - C&S Marine - OJ Propellers
green and blue are the 2 colors that penetrate the water the futhest...
I have not used Roswell or Showdow Casters... I have used Hurleys in my last boat.
Just FYI, Lifeform 9s, even at their regular advertised $360 price, are the undisputed best buy in price $ per lumen at 2,637 lumens ea. And often can be had cheaper thru their periodic promo sales... This fall I bought a pair off an add they had on Facebook a while back...I think I paid $310? just had them installed, enabled the OEM feature for control on the Link screen. very sturdy quality product. 2600 lumens is blinding.
Keep in mind OEM LEDs are around 1000 lumens ea for reference. If a manf doesnt post the tested and spec'd lumens, thats should tell you something, you dont bring a product to market and forget to test it.
Focus on the price per lumen, and try to get above 2000, aluminum housing, thermal protect... most everything else is just advertising noise.Last edited by nyryan2001; 03-03-2014, 02:49 PM.2019 G23 450
2014 G23 550
2013 G23 450
2011 Malibu Wakesetter 247
2007 Yamaha AR210
http://www.foilforum.com/forums/show...erwater+lights
I bought mine through Alibaba.com.... Site connects you directly to the factories in China where most are made. You use an escrow company to make sure you get your product. Been running them for 6 months and so far so good. RF remote can change the color while under power anywhere in the boat!
Look similar
http://www.alibaba.com/product-detai...946717455.html
http://www.roswellwakeair.com/series...es_nightwater/Last edited by EchoLodge; 03-03-2014, 05:15 PM.sigpic
I look at underwater light specs like this. Lumens is mainly an unqualified specification as used which gives vendor by vendor the freedom to stretch the truth. And some really streeeeetttttccccch the truth while others are more conservative. Some are measured over a narrow beam because their light is more of a spot. But I don't want a spot. I want a flood. And if you measure a flood like you would a spot, it doesn't spec well....but it performs well.
Every different color will have a dramatically different lumen output. Rarely is this actually reflected in the specs. You often just get the best case scenario.
White, blue, and green transmit well under water. The red bandwidth is poor, especially in murky water. If your boat has a lot of red graphics or a red hull then you might consider white or blue.
With all LED lighting, the efficiency is essentially the same. So I look at amperage draw as a more realistic representation of output. Both testing and experience proves this to be a better way of judging the light power.
- Sep 2012
- 736
- Indianapolis Indiana
- 1986 2001 ski nautique 68 correct craft skylark
I got the Roswell pieces in my hands about a week ago. We hooked them up and did some side by side comparison on a boat with the SCs. It's hard to tell what is actually brighter because both just blind you no matter what. We did a wall test. What we found on the wall test is the SC seems to have a more concentrated beam spread in a small plane. The Roswell lights lit a larger area to slightly less brightness but I attribute that on the wall to the beam being less concentrated and fanning out in a more radial fashion instead of being on a more flat plane. The lumen rating on the Roswell pieces is through the roof. We have a few customers who have showed interest in these lights so hopefully here soon we will have a set in the water to give full info. Nightwater pro is the light to use if you night surf. They will not overheat like the lesser L6. If you only run the lights when you are sitting in the water than save yourself some cash and go with the L6. The Roswell lights also feature glass lenses vs polymer lenses so the longevity may be better. The SC has larger and less LED chips the Roswell has smaller and twice to 3 times as many chips.[EMAIL="Zach@n3boatworks.com"]Zach@n3boatworks.com[/EMAIL]
- Sep 2012
- 736
They have a neat little connector that also comes with a long pigtail for the boat side. I threw my hand up for a size reference. That is the 4" vs the 6". That measurement is the OD of the housing not the light area size. You could heat shrink the connectors and it would seal up nicely. They require one hole for the wiring pass thru to be wired in and then two holes to hold the attaching screws from the back side. The 6" is rated at somewhere around 9000 lumens Ahhhhhh. The only color not available in the pro is red.[EMAIL="Zach@n3boatworks.com"]Zach@n3boatworks.com[/EMAIL]
If anybody here runs RC cars you will see that the connector is a Deans plug. They are relative inexpensive and are used to transfer power to the motor from the battery. Here is the link http://www.wsdeans.com/products/plugs/index.htmlNautiqueless in San Diego
