Installation is easy. You just drill a hole for the mounting bolts and wiring to pass through. The boat wiring is already in place. Just hook them up and activate the underwater light feature in the Deaker Settings screen in LINC and you’re all set.
- Mar 2002
- 16457
- Lake Norman
- Mooresville, NC
Thanks Jeff. I ended up finding the Attwood Light Armor 12 LED's in stainless, looks to be the factory underwater lights. At 3,500 lumens for the 12's, they come in quite a bit brighter, for a little more money, $250 per side. Trying to keep it as factory as possible. Install should be the same. greatly appreciated.
Interested as well. I have 2 quotes to have a dealer do this and I am $1000 at one and $1200 at the other.
1. $549 ea + Freight + Labor = $1238
2. Total of $956.66 which included the 2 hours of labor to install the lights.
In going through the links on the forum, here is what I have found for some pricing -
Shadow caster - $790
LIfeforms - $339 - 2600 lumens
Roswell Marine -
Night Wave $399 - 3000 lumens
L6 - $239
Attwood Marine (Factory lights) -
Lightarmor - 6 HP - 3200 lumens - $263
6 HPX - 5000 lumens $370
Wakemakers site -
Roswell Night wave - $360
L6 - $215
Originally posted by Randy1833 View Post
Any my idea if the two black wiring connectors in the middle of the photograph are the factory prewired light connectors? The photo shows the rear starboard corner inside the engine compartment.
Thanks
What type of connector did you use?
Did you install an inline fuse?
I’m assuming this is the correct wiring harness. Too much of a coincidence that two sets of wires (two harnesses) are just sitting in the engine compartment with connectors. Any one have any information on programming the “Dealer Settings” to program the lights on my 2017 Linc 2.0? It would be greatly appreciated, Thanks.lLast edited by Randy1833; 06-16-2018, 07:38 AM.
Dealers can typically access "dealer settings" mode.
Blue is illumination, just need to confirm that that blue to activated by the underwater light output once its activated in the link, unless its tagged at the underwater. I would expect there is a 2nd blue/black pair on the other side, rather then one blue/black for 2 lights.
Originally posted by Randy1833 View PostI’m assuming this is the correct wiring harness. Too much of a coincidence that two sets of wires (two harnesses) are just sitting in the engine compartment with connectors. Any one have any information on programming the “Dealer Settings” to program the lights on my 2017 Linc 2.0? It would be greatly appreciated, Thanks.l
Nautique customer service was nice enough to confirm the wiring for me, black and blue bundle on each side in the engine compartmentment. Programmed it into the LINC 2.0, five minute job, and confirmed it with my voltage meter. Crimp connected the lights, and all done. Final check with a short burst of the new underwater lights. Very pleased with the results.
Originally posted by Randy1833 View PostNautique customer service was nice enough to confirm the wiring for me, black and blue bundle on each side in the engine compartmentment. Programmed it into the LINC 2.0, five minute job, and confirmed it with my voltage meter. Crimp connected the lights, and all done. Final check with a short burst of the new underwater lights. Very pleased with the results.
I like the look of everything but was thinking of a different light. Either the Roswell or the Lifeforms.
