I have aconstant “hiss” sound through my speakers when the volume is turned down fairlylow to no volume at all. With the volume turned up the “hiss” goes undetectedthat I can tell. Please note this is a “hiss”not a “whine” that is commonly producedfrom an alternator noise. The hiss is constant and does not get louder with anincrease in engine RPM etc or increase in volume. The hiss is there when theengine is off and system on as well.
Here is abit of information that I hope helps:
Boat: 2008 SANTE210
As far as I can track down the ground for the 600.2 isrunning directly to the port battery post and the ground for the XDi805 isrunning to the existing ground wire that is in the stock wiring harness for thefactory (old) Polk amp. I assume it is running to the battery selector switch.I have not been able to determine where the ground for the head unit is runningto specifically however, it appears to be tied into some other ground wiresrunning to ???.
12v positive power to both amps is being supplied by one ofthe original wires from the circuit breaker and the other positive wire isgoing to the positive battery selector switch on the starboard side of the boat. Any assistance in how to proceed fromhere to eliminate the hiss will be greatly appreciated. I had a local marinestereo service due the amp upgrades last year and have been really disappointedin the install details to say the least, and don’t care to take it back norrecommend them to others in my area.
Boat: 2008 SANTE210
- Clarion CMD 5 head unit with remote (I do notuse the head unit other than to power on the system) Remote is set to AUX.
- WS 420 EQ- It is the model before the presentmodel out now
- Arc Audio XDi805 amp for in boat speakers and WS10 subwoofer
- Arc Audio 600.2 amp for WS Pro 485 towerspeakers
