I've got an '03 AN 216 with 6 inboat speakers, 2 Rev 8s and a sub. I've got a Wetsounds HT6 (110X6) powering the inboat speakers, a Wetsounds HT4 bridged (300x2) running the Rev 8s and an Alpine (300x1) running the sub. I've got 1/0 running from my perko switch and starter battery (where my 2nd battery negative is tied into) to a distribution block. Then the amps have 4GA from the distribution blocks. I also have a Wetsounds 420SQ tied in the mix. I want to redo how and where everything is mounted and can't fit the HT4 and Alpine in the space I want to put the amps and distribution blocks. So my thought is off the HT4 and Alpine amps and get another HT6 to run the sub and Rev 8s since power (RMS) would be the same.
Wetsounds website says max current rating is 60A for the HT6 but if I plug the numbers (600W and 900W max) into http://www.bcae1.com/images/swfs/sys...assistant2.swf it tells me to use a 60A and 90A fuse to protect them so now I am confused. I also want to tie a marine circuit breaker into the 1/0 vs an ANL fuse because of where it is located in my battery compartment and the potential of getting wet from people walking around the boat. 1/0 is rated for like 300+ amps but clearly I don't need that because of what is down stream.
So my questions ...
1) any reason I wouldn't want to combine my tower speakers and sub on a single HT6 amp?
2) what size fuses do I need to protect the inboat HT6 (660W at peak) and Rev8/Sub HT6 (900W at peak bridged)?
3) what size fuse/circuit breaker should I run on the 1/0?
So my questions ...
