Rev 8 or Rev 10
  • lucky7t
    • Mar 2011
    • 1306
    • Oklahoma
    • 2015 SANTE
    Rev 8 or Rev 10
    Got a quote for Rev 8's (four ) and it's only 200 more for Rev 10's plus tax. Should I go 8 or 10?
    These are on a 2012 210 fct5 tower
    Current Correct Craft Boat
    Correct Craft Boats Owned
  • EarmarkMarine
    • Mar 2008
    • 699
    • Dallas, TX
    That depends. Do you have enough headroom for the 10's? Do you have enough amplifier for the 10's (that could raise the price of the total upgrade a bit more). If you have the room and the power then the REV10's will definitely be a step up in performance.
    Odin
    www.earmarkmarine.com[/URL]
    • axeman
      • Apr 2012
      • 387
      • Dallas, TX
      • 2016 Super Air Nautique 230
      Rev10
      • nyryan2001
        • Mar 2013
        • 1993
        • Lake Anna
        Rev10s if you have the headroom and can provide 350-400w per Rev10
        2019 G23 450
        2014 G23 550
        2013 G23 450
        2011 Malibu Wakesetter 247
        2007 Yamaha AR210
        • OKWAKEBDR
          • 750
          • Lakefront
          • 2017 Super Air Nautique G23
          Which bimini do you have? If you have a Z5, the Rev10s will not fit without drastic modifications to the bimini. The Rev8s won't fit either unless you buy the lowering kit from Z5.
          Other than that, like the others said, it depends on the headroom.
          With the proper power, the Rev10s do sound better than the Rev8s. (I have the Rev8s.)
          Current: 2017 G23
          • lucky7t
            • Mar 2011
            • 1306
            • Oklahoma
            • 2015 SANTE
            Rev 8 or Rev 10
            Decided on Rev 8's. I was extremely disappointed with the xs650's so I'm sure these will be a huge change. I have a stock Bimini.
            Thank you for all of your replies
            • axeman
              • Apr 2012
              • 387
              • Dallas, TX
              You don't need to make any modifications to the Z5 on a 2012 210/230 with REV10s. I had that same setup on my 2012 230 without any issues.
              • Garrett Burke
                • Apr 2013
                • 51
                • Houston tx
                • 2016 g23-2017 t-minus mid aug!
                I've had both I like the rev8s sound better and higher volumes
