Dumb question
  • Shockthis
    • Mar 2013
    • 302
    • Christina Lake BC
    • 2021 centurion ri245
    Dumb question
    So just sitting in the boat for the first time, on a 2013 210 and playing with the stereo, how come the in boat speakers cut out when I put the volume over 23. The tower speakers stay on but not the in boat speakers.what is wrong?
    Also is there aux import other than the USB ?
  • cedarcreek216
    • Oct 2009
    • 1009
    • Dallas, TX
    • 2018 210 2013 210 2009 216V
    On ours there is an Aux input for headphone to headphone in the glove box and in the little pocket to the left of the setting wheel. There is a flip open cover with a USB and a headphone input. Not sure what to tell you about the speakers clipping out.
    • 4th ski-doo
      • Apr 2013
      • 307
      • Wilmington
      • 2013 SANTE210 2011 Sport200V 1994 Bimini Skier 190 1986 Master Craft Pro Star 190
      There are a lot of settings in the radio once you get in including loudness settings.
      2013 SANTE 210
      2011 Sport 200 V
      1994 Bimini Skier Pro 190
      • Shockthis
        • Mar 2013
        • 302
        • Christina Lake BC
        So when I turn it up the boat speaker amp goes into protection mode. What does that mean?
        • nyryan2001
          • Mar 2013
          • 1993
          • Lake Anna
          ^^^ this is not right, you have an issue.
          I know on the 2013 Gs there was an AUX input grounding issue on an AUX input mounting plate... that would get worse as you turned up the volume and could put the stereo into protect.... suggest you call your dealer.
          Loose suggestion would be that you have a stereo wire grounded somewhere.
          One quick way to diagnose is to
          remove all the aux inputs and remote control inputs and crank the volume up manually at the head unit--- see if the speakers cut out into protect--would verify if you have a grounded RCA at your AUX ins
          disconnect your right speaker wires at the amp... then reconnect and then the left... and crank each of them up.... that'll determine if you have a speaker wire grounded down stream.
          2019 G23 450
          2014 G23 550
          2013 G23 450
          2011 Malibu Wakesetter 247
          2007 Yamaha AR210
          • OKWAKEBDR
            • 750
            • Lakefront
            • 2017 Super Air Nautique G23
            Your amp is probably dying. I had the same problem and had to replace mine (under warranty).
            Current: 2017 G23
            • 4th ski-doo
              • Apr 2013
              • 307
              • Wilmington
              I got onto settings that cleared mine up but in all honesty these guys are right and it could possibly be all of these things. I'm curious about the bad amp tho. I had no volume and when I turned it up it cut out but after finding the loudness settings it was better but in all honesty my 2011 Sport sounded way better
              2013 SANTE 210
              2011 Sport 200 V
              • Shockthis
                • Mar 2013
                • 302
                • Christina Lake BC
                Would it be because I didn't have the boat on? just wondering if there is enough power to drive the amp.
                • MLA
                  • Dec 2009
                  • 1312
                  • Lake Wylie NC Area
                  I would say this is a very real possibility. The battery is likely low. I would check and charge the battery(s) and then play the system again. Incorrectly wired load on any of the chnls will put the amp into protect mode as well.
                  • axeman
                    • Apr 2012
                    • 387
                    • Dallas, TX
                    • 2016 Super Air Nautique 230
                    I agree with MLA. I've had this happen before with the boat off and the batteries low.
                    i would still check out all the other suggestions as well.
                    • lucky7t
                      • Mar 2011
                      • 1306
                      • Oklahoma
                      • 2015 SANTE
                      I believe it's a power issue. Stick a voltmeter on battery and see what it is. Amps will get hot without correct power.
                      Current Correct Craft Boat
                      Correct Craft Boats Owned
                      • Shockthis
                        • Mar 2013
                        • 302
                        • Christina Lake BC
                        so I charged the batteries and tried it again. There was no change. I noticed that when the in boat speakers amp kicks off into protect mode, the led lights on the tower speakers would start blinking. Is this normal or just a new disco feature.
                        • MLA
                          • Dec 2009
                          • 1312
                          Did you measure the voltage of the batteries? You can air up a leaking tire all you want, its still a leaking tire. You can charge a bad battery and its still a bad battery.
                          • Shockthis
                            • Mar 2013
                            • 302
                            • Christina Lake BC
                            I guess I need to get a voltage meter tomorrow. What is the reading I need.
                            Is the light issue on the tower speakers normal?
                            • Shockthis
                              • Mar 2013
                              • 302
                              • Christina Lake BC
                              Where are these loudness settings?
