Tower Speaker Wire Rubber Jeacket Replacement?
  • barefootinjimmy
    • Aug 2012
    • 138
    • Kearsley Lake, MI
    • 2005 Super Air Nautique
    I am powder coating my tower, and I want to replace the worn speaker wirer rubber jacket.
    Has anyone found a good replacement wire jacket?
    And does anyone know how to disassemble the speaker connector?
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    Are you referring to a short length of heat shrink that was uses to dress up the service loop on each side of the connector? If so, you would need to remove the terminals from the connector body in order to put on a new section. If on a section that has no connector, but just a service loop that jumps from one section of tower to another where is cant pass through, you would have to disconnect from one end and pull the harness out of the tower.
    • beach
      • Jul 2010
      • 245
      • Alabama
      • 2003 SAN 210
      He would have to remove all the wiring to powdercoat it.
      Could you post a picture of the connector? If it's a deutsch connector, then it'll be fairly easy to dissasemble. Look at end of this video, it shows you how to dissemble the connector.
      http://youtu.be/LIR9-ZdG958
      • 4th ski-doo
        • Apr 2013
        • 307
        • Wilmington
        • 2013 SANTE210 2011 Sport200V 1994 Bimini Skier 190 1986 Master Craft Pro Star 190
        Heat shrink. I'm a moron and figured those plugs out, just make notes of what color wire went in what number position.
        2013 SANTE 210
        2011 Sport 200 V
        1994 Bimini Skier Pro 190
