10 " sub trim ring install need help.
  • RacingSims
    • May 2012
    • 207
    • Somers,Ct
    • 2013 Super Air 210
    I had a trim ring fabricated to install the infinite baffle sub in a 2013 210. Am I to assume the ring goes on the inside of the panel or outside? Also it seems the sub is too deep to fit in the location. Help is much appreciated.
  • cedarcreek216
    • Oct 2009
    • 1009
    • Dallas, TX
    • 2018 210 2013 210 2009 216V
    They put mine on the inside so the speaker sits flush as intended. What sub are you trying to put in there? The JL IB fit perfectly in my stock location.
    • David Analog
      • Sep 2013
      • 263
      • Dallas
      A woofer baffle ring serves two purposes. Adds rigidity to the coaming panel. Offers a better material to seat the woofer mounting screws into. The ring gets pre-loaded from behind and the set screws are concealed by the woofer's outer rim and grill. So having to frontload the ring behind the panel often requires a split ring or 2-piece ring unless you have access from behind.
      If the sub is too deep then a trim/spacer ring might be necessary. The trim ring could be vinyl clad birch or KingStarboard.
      • RacingSims
        • May 2012
        • 207
        • Somers,Ct
        Thanks seeing that the internal wall was reinforced with an added thickness of fiberglass factory stock I am going to use the birch ring on the outside to keep the sub from resting against the hull.
