Amps Getting Wet
  • tgator96
    • Jun 2011
    • 127
    • Gainesville, FL
    • 2012 SANTE 230 ZR 409 2010 SANTE 210 (sold)
    Amps Getting Wet
    Hey, guys. I've got a 2012 SAN 230 and am now on my my 3d Wetsounds amp for the tower speakers. Water damage is the issue. It's mounted just above the factory installed amp under the passenger glove box. I'm having the wetsounds dealer build a ventilated, water-tight box for the amps but am wondering if anyone else has had this problem or if anyone has some insights into how it's getting so wet in there. It gets caught in a lot of rain in the summer but I just don't understand how it's getting we in that spot.
  • TxJole
    • Jun 2009
    • 898
    • Cedar Creek Lake TEXAS
    Been there, done that, fixed that. Water, in my case, was coming in from the horn cover, tower leg, hole drilled on deck for wires or all of the above. Abs plastic bent with a heat gun and some abs blocks mounted to the backer plate. Added the clear plexi for giggles. It has a large Wetsounds decal on it now, looks better.
    • xrichard
      • Aug 2008
      • 669
      • El Dorado Hills
      • 2023 G23
      Txjole pointed out the likely entry points. Another common leak point, at least on the earlier 210s, is the hull/deck bond.
      On my boat, I was getting water under the observer seat and we couldn't figure out where it came from. The dealer pulled the rub rail and sealed the deck joint, but the water persisted. I eventually traced it to the docking lights. The water stayed fairly high along the side of the hull--probably wicked by the carpet. The floor area under the observer seat would get soaked.
      Previous boats:
      2015 G23
      2008 SAN 210
      2002 XStar
      1995 Sport Nautique
      • MLA
        • Dec 2009
        • 1312
        • Lake Wylie NC Area
        I would start by attacking the source of the water. Fix that, and an elaborate shroud or cover may not be needed.
        • TxJole
          • Jun 2009
          • 898
          I will add I did re caulk the wire hole, made a fabric skin out of an outerwear pre filter I had to go under the horn vent. Have not seen water since. I built the cover as added security. Plus it keeps bags and towels from laying on the amps and over heating them. Cheap insurance since everything I used was scrap laying around. They don't give these amps away$$$$$$$
          • ski4evr
            • May 2010
            • 613
            • Bowling Green, KY
            • 2005 SV 211
            I had water issues through horn port. I used a small piece of black goretex and sealed it up to the hull and horn cover. totally invisible and waterproof. can still hear horn too!
            2005 SV-211
            • Ponger
              • Jul 2014
              • 12
              • Tulsa OK
              • 2013 Team 230
              Very nice. Looks great.
