amp rack material
  • RacingSims
    • May 2012
    • 207
    • Somers,Ct
    • 2013 Super Air 210
    amp rack material
    Looking to build an amp rack any idea what material I should look for.What does nautique use. Thanks
  • kopp210
    • Jun 2006
    • 129
    • IN
    • 2013 G23 550 2007 236 6.0 (All White Ghost Ship) 2003 210 PYTHON (RRRRhhhaaa!!!!)
    I use "starboard" which is hdpe. Then you can wrap it in carpet or whatever you want.
    • ski4evr
      • May 2010
      • 613
      • Bowling Green, KY
      • 2005 SV 211
      Cheaper version is Advantech subflooring. You can find it on any housing job site. 50 year guarantee.
      2005 SV-211
      • barefootinjimmy
        • Aug 2012
        • 138
        • Kearsley Lake, MI
        • 2005 Super Air Nautique
        What is starboard or hdpe?
        How thick is this board?
        I wanted to add another amp for the two speakers in the open bow area.
        I wanted to mount the amp using the inter bulkheard or wall.
        On my 2005 SANTE the two existing amps are located on the portside(passenger side) inter gunnel.
        I wanted to keep this new amp in the same area (area behind the seat).
        Since I wanted to use the existing bolts, I wanted to keep the amp board thin.
        I wanted to use 1/4" plywood. Possibly using a fiber glass coating, and carpet
        • kopp210
          • Jun 2006
          • 129
          • IN
          It's just a plastic material that is easily worked with common tools. Drill saw route as if it were plywood but it will last in marine environment.
          When I have a project I usually watch ebay. You can usually pick up scraps big enough for a fair price. Sheets get expensive.
          • hudd210te
            • Jun 2008
            • 47
            • napoleon ohio
            I seen this in my local menards store. Unfortunately there isn't one in MA, but maybe you have a similar home improvement store.
            http://www.menards.com/main/c-14048.htm
            2012 210 sante zr450
            2003 210 sante ex343
            • s_kelley2000
              • 1575
              • Fort Meadow Recevoir
              • Mass
              I'm not sure on the size you need but I have heard of people having good luck with plastic cutting boards. Cheap and easy enough to drill and cut to size.
              http://www.walmart.com/ip/Mainstays-...Board/13397990
              Shawn
              2012 Blue Metal Flake SAN 230
              • TxJole
                • Jun 2009
                • 898
                • Cedar Creek Lake TEXAS
                If you have a Spec liquor store around they sell bar grad cutting boards made of hdpe that are huge and you can get in many colors.
                • RacingSims
                  • May 2012
                  • 207
                  • Somers,Ct
                  I think we have a winner!!! Thanks all for the rsponses.
                  • Chexi
                    • Feb 2025
                    • 2119
                    • Austin
                    • 2000 SAN
                    Or check here. Very inexpensive.
                    http://www.webstaurantstore.com/3059...ng-boards.html
                    Now
                    2000 SAN
                    Previously
                    1999 Air Nautique
                    1996 Tige Pre-2000
                    • lucky7t
                      • Mar 2011
                      • 1306
                      • Oklahoma
                      • 2015 SANTE
                      Old thread but I have used an old wakeboard in the past. Looks kinda cool and works great
                      Current Correct Craft Boat
                      Correct Craft Boats Owned
