Looking for a Little Midrange Amp Help
  • swatguy
    • 1631
    • Midwest/ Northern IL
    • 2008 SANTE 210
    So I have
    (6) Polk MOMO MMC650's in the boat 80watts RMS each 4ohms INBOATS
    (4)Polk MOMO MMC690's on the tower wired in Parallel so 2ohms each speaker with 100Watts RMS TOWER
    (1)Polk MOMO MM2104 10 inch 4ohm sub at 300watts rms
    Was tossing around the PPI Phantom Series
    or the Soundstream Tarantula series. I had full Wetsounds setups over the past years (Most recent (2) Syn 4's running 12inch sub, (4)XS650's and 2 Rev 8's) but my stereo use has been toned down a bit since selling the boat with the Wetsounds System. I am leaning towards just upping the factory amps vs. gutting an entire setup. The Polks are very competent, but I will be taking a huge hit on the tower keeping (4) 6X9's up there. Both PPI's are Class D, but the Soundstream (5) channel has an AB and a D amp inside Any downside to this vs the PPI 900.5? The wattage is little better than the PPI. Any other Midrange amps I may be missing? Any thoughts. As just looking to power everything nicely.
    Precision Power 900.5 Phantom Series Class D Full Range 5-Channel Car Amplifier
    RMS Power Rating:
    4 ohms: 70 watts x 4 chan. + 270 watts x 1 chan.
    2 ohms: 115 watts x 4 chan. + 440 watts x 1 chan.
    Bridged, 4 ohms: 230 watts x 2 chan. + 440 watts x 1 chan.
    Tarantula TN5.950D NANO Series 5-Channel Class AB/D Car Amplifier
    Includes Class D Full Range SMT circuitry
    RMS Power Rating:
    4 ohms: 85 watts x 4 chan. and 270 watts x 1 chan.
    2 ohms: 130 watts x 4 chan. and 430 watts x 1 chan.
    Max power output: 950 watts
    Dash mounted remote gain control
    Variable Bass Boost (0 to +12 dB bass boost at 50 Hz)
    Double sided composite epoxy PCB
    5/4/3/2 or Mono channel operation
    Delayed on/off circuit
    Variable high-pass filter
    Signal to noise ratio: 100dB
    Tri-mode capable
    PPI 600.2 Phantom Series Class-D Full Range 2-Channel Car Amplifier
    RMS Power Rating (14.4V):
    4 ohms: 190 watts x 2 chan.
    2 ohms: 300 watts x 2 chan.
    Bridged, 4 ohms: 600 watts x 1 chan.
    RMS Power Rating (12V):
    4 ohms: 100 watts x 2 chan.
    2 ohms: 200 watts x 2 chan.
    Bridged, 4 ohms: 400 watts x 1 chan.
    Tarantula TN 2.600 NANO Series 2-Channel Class D Car Amplifier
    Full range SMT Class D circuitry
    RMS Power Rating:
    4 ohms: 200 watts x 2 chan.
    Signal to noise ratio: 94dB
    Tri-mode capable
    Three-way protection circuitry
