Amplifier alternatives for Rev10s?
  • scarbs
    • Aug 2009
    • 450
    • Arizona
    • 2017 G23
    Hey guys...thinking about adding some Rev10s to my tower. What are the amplifier options that produce the power needed for these monsters?
    Thanks!
    2017 G23
    2012 210 TE
    1999 SAN
    1995 Sport
    1991 Sport
  • Paxdad
    • Mar 2013
    • 775
    • Cumming, GA
    • 2008 210 SANTE
    You will be very happy with a Arc Audio 600.2.
    2008 210 SANTE
    • MLA
      • Dec 2009
      • 1312
      • Lake Wylie NC Area
      At a minimum, the Wet Sounds HT-4 or Arc XDi-6004
      Ideal, Wet Sounds Syn-4, SD-2, JL HD750/1
      • scarbs
        • Aug 2009
        • 450
        • Arizona
        • 2017 G23
        One HD750,1 for two Rev10s? Or one each? Thanks!
        2017 G23
        2012 210 TE
        1999 SAN
        1995 Sport
        1991 Sport
        • MLA
          • Dec 2009
          • 1312
          Single HD750/1 for a pair of Rev-10. 2 ohm load at the amp. nets 375W rms.
          • scarbs
            • Aug 2009
            • 450
            • Arizona
            • 2017 G23
            Thank you!
            2017 G23
            2012 210 TE
            1999 SAN
            1995 Sport
            1991 Sport
            • nyryan2001
              • Mar 2013
              • 1993
              • Lake Anna
              Polk PA 4000.4 bench tests at 420x2 for under $300.
              2019 G23 450
              2014 G23 550
              2013 G23 450
              2011 Malibu Wakesetter 247
              2007 Yamaha AR210
              • MLA
                • Dec 2009
                • 1312
                ^^^^ Certainly has wattage, but the sound quality is lacking as compared to other quality amps.
                • scarbs
                  • Aug 2009
                  • 450
                  • Arizona
                  • 2017 G23
                  I read on another forum that some are using the PPI 900.4 to power two Rev10s. I'd be interested in your opinion(s) on that amp for this application...thanks.
                  2017 G23
                  2012 210 TE
                  1999 SAN
                  1995 Sport
                  1991 Sport
                  • MLA
                    • Dec 2009
                    • 1312
                    The PPi Phantom series 900.4 is basically the same guts as the Polk. They use an open-tooling manufacturer. Ive demo'd both brands with a few different HLCDs, with similar mediocre results as compared to to Wet Sounds, JL, Arc and other amps.
                    • scarbs
                      • Aug 2009
                      • 450
                      • Arizona
                      • 2017 G23
                      Got it...thank you very much.
                      2017 G23
                      2012 210 TE
                      1999 SAN
                      1995 Sport
                      1991 Sport
                      • TN_Rider
                        • Mar 2012
                        • 53
                        • Tenessee
                        I have a syn 4 on each pair of my rev10 crazy loud!
                        • scarbs
                          • Aug 2009
                          • 450
                          • Arizona
                          • 2017 G23
                          After the JL Audio rep told me that the HD 750/1 no longer works with the Rev10s, I went with an Arc Audio 600.2. Thanks for all of the help!
                          2017 G23
                          2012 210 TE
                          1999 SAN
                          1995 Sport
                          1991 Sport
                          • kopp210
                            • Jun 2006
                            • 129
                            • IN
                            • 2013 G23 550 2007 236 6.0 (All White Ghost Ship) 2003 210 PYTHON (RRRRhhhaaa!!!!)
                            How do they no longer work?
                            • David Analog
                              • Sep 2013
                              • 263
                              • Dallas
                              Don't worry about the HD750/1 being able to drive the Rev10s. It's fine and widely used.
                              JL Audio is very conservative and they made a change in the full range vs wide range status. But they have been tested and the top end response still exceeds what you can hear from any tower speaker.
