Water in rev 10
  • tasnautique
    • Apr 2014
    • 6
    • tasmania,australia
    • 2000 san
    Water in rev 10
    So I had my tower folded forward so the speakers were pointing straight up and it rained, water went straight into the front of one of the speakers. Should I dissasemble the speaker to dry it out? And if so what is the correct procedure for this.
    Cheers
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    Yes, pull the grill off, remove the driver. Blow dry the cross-over, pod, mid-bass driver and compression driver and then let air dry. You're the first to have this happen with that style of tower.
    • tasnautique
      • Apr 2014
      • 6
      • 2000 san
      Ok thanks MLA I will do that and try to be more careful in the future. On a side note I am very happy with the performance of the speakers I ended up running a syn 4 bridged. Only issue is a bit of ground noise coming through the speakers that I have to try eliminate.
