I have a kicker 250.2 amp and am getting a kicker 350.4. What gauge wire should i be running? Thanks -MG
RE: What Gauge wire?
power and ground. The amps will be at most 8 feet away from the battery. I was thinking using one 4 gauge power cable with a 60 amp fuse into a distribution block that separates into two 8 gauge cables to the two amps. Same for the ground but without the fuse. Does that sound okay?
Also now that you mention it, with gauge speaker wire should i use?
Originally posted by HollywoodIn that case, the 4 will be fine. I wasn't aware you were keeping the other one and running both. 16 guage speaker wire is fine for most all speakers, including smaller subs.
I say the 4 G because with that length, if you use 8G wire, the resistance in the wire is going to be a little over 5 milli ohms, where as the 4 G will have less than 1/2 of that, not even 2 milli ohms.
Just somethin to think about.2018 SAN 230
1981 Ski Nautique
Sold - 2011 Sport 200V
Sold - 2000 SAN
