Ryan,
The way you have done your boat this time is totally fine. Absolutely zero wrong with it. However, just because you are using one method does not mean that it is the only way to go. If the charger amperage capacity is correctly matched with the battery reserve capacity and individual usage habits then there will be no issue either way. A mismatch will be an issue either way. What you did initially was probably wrong but for different reasons. It may have been a mismatch in capacity.
Here are some facts.
Many of the charger manufacturers clearly state on-line, in brochures, etc., that you can run more than one battery off of a single charger bank.
When in the industry, I have designed hundreds of marine audio systems, including far more complex systems in large boats. These methods work well. Problem free. Long lasting batteries.
Tournament fisherman often charge several trolling motor batteries off one charger bank. And these guys live and die by batteries. There is no alternator or stator connected to a trolling motor bank.
Motor yachts, valued at millions, charge more than one house battery off a single bank.
Powerful thrusters have their batteries driven off a single bank as original equipment.
You would have the OP believe that every one of these examples are wrong?
