Ok, some of my equipment has failed in the past and I have been getting by from re configuring my amps and using 2nd hand and old stuff I had laying around but enough is enough.
I am happy with the performance (prior to failures) of my system so I don't need to change any source or speakers.
Current setup.
4chan clarion apx680, 2 channels are dead so this runs 4 in boat speakers, 2 each in parallel off 2 channels.
4 chan Audiobahn (pos who cares what model) 3 channels are dead the remaining Chanel powers the Polk 10 in a vented enclosure.
4 chan Alpine Mrv f300 2 channels are dead so one channel supplies the tweeters in my Compression driver horns up top. Bugger all power required here but I want to keep separate from the drivers so I can tune them.
2 chan alpine Mrv 1507 bridged 450wrms to the 10" drivers up top. Just recently had a PS failure.
So here I am with a total of 4 amps. A total of 14 channels and only 5 work. I would love to run the whole system off 2 4chan amps.
Things that need power:
4 In boat 6.5's: I'd like 80-100wrms, happy to run off 2 channels @ 2ohms.
2 Tweeters for HLCD: only need about 20wrms
2 10" HLCD drivers: preferably 400rms+ these are the only power hungry drivers in the boat and are in a small sealed enclosure.
1 10" Sub: being small and in an efficient enclosure probably only needs 150-200rms
What are your thoughts? 2 big 4 channels?
A 5 channel and keep the tweeter amp in there (it has x-over multiiers which is good for tunning the tweeters)
I'd love to reclaim some space that 4 amps take up.
Edit: failures my own fault. Forgot to re attach cup holder drain and water got to 3 of the amps.
Current setup.
