2005 SANTE How is the +/- 12Vdc battery routed to the ampliier location?
  • barefootinjimmy
    • Aug 2012
    • 138
    • Kearsley Lake, MI
    • 2005 Super Air Nautique
    I had an amplifier go bad due to a less than perfect +/- 12Vdc battery supply. So I wanted to add another set of +/- 12Vdc battery wires to the amplifier area, and an additional amplifier. I would like to use the same routing as stock.
    Any one know how the path from the two battery switch, to the passenger storage area, basically where the stock Clarion Amplifiers are located? I would like to buy the wire before I dis-assemble the interior.
  • Paxdad
    • Mar 2013
    • 775
    • Cumming, GA
    • 2008 210 SANTE
    It should run up from the switch/ panel and follow the wiring harness along the inside of the gunwale and then down to the amp.
    2008 210 SANTE
