Venting the sub / storage compartment G23
  • Kporsch
    • May 2013
    • 121
    • Houston
    • 2018 G23
    #31
    I just got done installing the Roswell box and sub in my G23. I was on the fence on whether or not to put the Roswell sub or go with a well known brand sub in the Roswell box. I am very impressed with the Roswell sub - it is much better than I expected. This setup is not cheap, but the quality of the box is excellent and keeps that factory look. I ordered from nautiqueparts.com. They were excellent to work with.
    • Kporsch
      • May 2013
      • 121
      • Houston
      • 2018 G23
      #32
      Here is a pic:
      • trip33
        • Nov 2010
        • 248
        • Odessa, FL
        #33
        Sorry for the basic question, not exactly an audiophile but will venting the observer compartment with the stock sub make an improvement, or is it better to install a new sub in a box?
        Kporsch - what model JL amps are those?
        • nauty220
          • Apr 2008
          • 230
          • Friendswood TX
          #34
          Trip,
          I don't have much experience with the oem sub setups but if the sub sounds better with the seat open then venting would help.
          2014 G23 450 Coastal Edition
          2013 G23 450 Coastal Edition
          2010 SANTE 230
          2007 SANTE 220
          2003 SANTE 210
          • Kporsch
            • May 2013
            • 121
            • Houston
            • 2018 G23
            #35
            Trip, they are MHD900/5 for sub and 4 interior and MHD750/1 running one pair of rev10s
            • David Analog
              • Sep 2013
              • 263
              • Dallas
              #36
              I like the idea of the vent located lower and against the sole and within the confines of the cockpit, rather than higher and in the walk-thru even though the surface area of the walk-thru vent may be larger.
              • Dandy21
                • Jun 2014
                • 159
                • Minnesota
                #37
                Since we are talking about upgrading the sub output on a G23 - other than the venting and the Roswell box combo, what other options have you all done to improve the sub sound/volume in the boat? The Roswell box looks great, however I don't like the idea of giving up the extra storage under the observers seat. I have not yet installed our vent, maybe it will be enough, maybe not. Ideally I would like to optimize the factory sub location. Suggestions?
                • nauty220
                  • Apr 2008
                  • 230
                  • Friendswood TX
                  #38
                  You could look into installing a sub on the driver side. I have one on both sides.
                  2010 SANTE 230
                  2007 SANTE 220
                  2003 SANTE 210
                  • Cpan13
                    • Jan 2016
                    • 343
                    • Canada
                    • Current - 2021 G23 โ€ฆ Previous - 2020 Supra SL450, 2015 G23, 2014 G21, 2012 Epic 21V
                    #39
                    Going to revive this thread because I'm really interested in that Roswell vent. Does anyone know if they make one in white? Black won't look great on my white gel coat.
                    • Switch
                      • Jun 2015
                      • 1
                      • Dallas
                      • 2015 G23
                      #40
                      I installed a JL M12IB6 in the factory location. I will probably redo the seadeck to match the contour better at some point.
                      Then I designed(close copy of one i saw) the port grill and cut it.
                      Cut a hole in the boat and glued it in.
                      It is white plastic with a slightly polished Stainless inlay. At some point i will install the LED's to match the rest of the boat.I also have a G23 logo to cut and install on the grill
                      • chrisschweda
                        • Sep 2010
                        • 140
                        • New Orleans
                        • 2015 G23
                        #41
                        I am looking to put 2 vents in my new G vs 1 has anyone done this wondering how much better it would sound. I made 13x9 vents I will do 1 where I put the 1 i posted in this thread but adding another either on the out wall under the flip up seat or in between the latches of the flip up seat.. Any input is appreciated
                        • scarbs
                          • Aug 2009
                          • 450
                          • Arizona
                          • 2017 G23
                          #42
                          They do not. But another user on this site painted some white and they look pretty good.
                          2017 G23
                          2012 210 TE
                          1999 SAN
                          1995 Sport
                          1991 Sport
