Bluetooth - - Roswell Cybox
  • MinnesotaNautique
    • Jan 2004
    • 207
    Anyone familiar with this device? We recently had it installed in our 13' Sport and can't figure out the volume level. At max volume it's still quite compressed...if i switch to the radio or cd it will nearly makes your ears bleed! I've inquired with some local dealers, but no solutions yet. Any suggestions would be appreciated...
  • jesutton3
    • Nov 2010
    • 93
    • Raleigh
    Check your phone to make sure the Bluetooth or Media volume is turned up.
    • First226
      • Jul 2014
      • 31
      • Denver
      • 2005 226 TE
      Welcome to the world have compressed and then compressed audio again. It is not likely that you will be able to compare a Bluetooth signal from a phone or other devise to a CD or Radio as the music was compressed when it was downloaded onto your phone and compressed again when it is sent over via Bluetooth.
      • zhadley
        • Sep 2013
        • 58
        • Redlands, CA
        • 2017 GS22 1992 Ski Nautique
        I just installed one as well and noticed the same thing. I had to turn the head unit and my phone volume way up.
        • swankster
          • Aug 2010
          • 1052
          • DFW, TX
          I don't need to hear this. I just had one put in, but have not tried it yet. The reviews I read didn't sound bad.
          2010 SANTE 230 343 (280hrs)
          • zhadley
            • Sep 2013
            • 58
            • Redlands, CA
            I decided to rewire it. Much more simple now. I mounted it it next to the tower amp and wired it to this amps main power supply and the remote turn on. It is working well so far. You do have to crank the volume but it does sound fine. I admit to not being an audiophile, but so far am pleased. Here is a pic of my how I hooked it up. Hopefully correctly.
            • zhadley
              • Sep 2013
              • 58
              • Redlands, CA
              oops, meant to post that in the other cybox thread
              • MinnesotaNautique
                • Jan 2004
                • 207
                Thank you for the input. Couple of updates:
                1) If you pull the cover off the cybox there is a swtich you can slide up or down that will affect the volume
                2) Depending on your head-unit, you will want to adjust the volume sensitivity for aux inputs.
                *These two changes made a huge difference in the volume levels. Hope this helps...
