Think I just blew my sub... Installed a remote for the driver sear to the amp... Now it just farts. If anyone has a solution that would be better since I'm poor, but if not anyone know of a good replacement to drop back into its place? 2012 230.
I would look at the amp's manuals and match a speaker to that... vice trying just to put the "stock" speaker. I know some of the polks have strange ratings (2.3 ohms??) So look at the amps ratings, and pick a 10" sub that would work for that.Last edited by nukemustang; 05-26-2015, 01:40 PM.
- Oct 2014
- 1026
- St. George, Utah
- Red Metal Flake 2016 G23! Malibu 25 LSV 2019 2021 Centurion Ri237
I would part with the sub in my Nautique. It is a 10 inch free air sub. Assuming that is the same thing that you already have. But if something you did made the sub blow, you need to fix that issue first, or you will just have a second blown sub.
Back more to the point, however, is that I would want to make sure exactly what happened here. I am concerned that you changed something and suddenly it does not work right. Does it still sound bad if you return it to the original configuration?
- Jan 2009
- 696
- SoCal
- 2012 SANTE 230 Previous: 2005 SANTE 210 1997 OG Air Nautique
I think once again MLA is right, good news $4 worth of glue and it's back, performing as normal (which still isn't great) but better than it was while separated; decided in the mean time to shop for deals for a true free air... anyone go with the JL 10 IB in that location and happy(ier) with it? or maybe the wetsounds free air 10?
