I'm planning on adding a 3rd amp to my boat to send adequate power to my tower speakers. The power supply to the 2 amps that are currently in the boat are routed through 60amp breakers in the breaker panel in the left rear compartment. My question is: Should I add another 60amp breaker to the breaker panel and run a power supply wire from this to the amp or should I just run a power supply cable straight from the battery to the amp with an inline fuse? The current power supply cables appear to be fairly small gauge like about 8 or 10 gauge. I was thinking that a 0 or 2 gauge power supply cable from the breaker panel would be better, but I'm not sure the best way to wire such a large gauge wire into the breaker panel.
I would like to keep it looking stock or "factory" installed, but it would be a lot easier to run a cable straight from the battery. Just looking for some ideas how to best accomplish this task.
Thanks in advance.
Thanks in advance.
