Alright so the 4th channel blew, on the PPI amp, I am not sure why. So I was forced to add a third amp. I hooked up a Wetsounds HT-4 to run the towers, a PD1000 running the sub, and switched the exile 400.4 to run the in boats. I had channel 1-2 running the bow at 4ohm, and channel 3-4 running the 4 in cabin speakers running at 2ohm. In the garage it sounded great. I ran it for about 20 mins and everything was great. Then I went on the water, and while the boat was running I was getting a ton of noise through the tower and in boat speakers. Then about 3 minutes into the boat being on the exile amp lost channel 3-4 also.
What is happening that is causing this to blow a single channel on the PPI and 2 channels on the exile? Also I don't know where the noise came from.
