Which splice connectors
  • a.klos
    • Dec 2007
    • 213
    • North Jersey
    • 2002 Super Sport
    I have WS HT-4 amp and I want to run 2 speakers(mm651um) per channel in parallel. I got an idea from the manual(8 speakers total)
    So how do I make a splice: running separate wire to each speaker and terminate them at the amp's channel screws or run wire and then make a pigtail connection at some point and then to separate speakers? What kind of Y connectors do I need if so? Does it make any sense?
    Thanx
  • nukemustang
    • Sep 2014
    • 410
    • Summerville, SC
    • Current Boat: 2018 GS20
    Either way you described (one wire split to two, or terminating at amp) is electrically equivalent, so it depends on if there is already existing wiring going to the speakers, or if you are running new wiring. If you are running new speaker wires, i would just terminate them at the amp, so if you change the config later, you have the max flexibility of already run wires.
    • a.klos
      • Dec 2007
      • 213
      • North Jersey
      • 2002 Super Sport
      Thanx Nekemustang, I was leaning towards homeruns too.
