I am interested once its confirmed it works on a 2nd generation 210 [2008].
Originally posted by pSchwade View Postare the bolts sticking out just in case you miss one of the kids you are trying to run over? JK, seriously though - Im kind of interested to see how this works... just make sure you dont sell any of them or you'll probably be looking at a copyright infringement lawsuit.19 SANTE 210
08 SANTE 210 ZR6
08 SANTE 230 ZR6
88 Baja Ski Sport- First boat
for this version I used this handle
http://www.amazon.com/COSMOS-Aluminu.../dp/B007VL3CB0
have not had a chance to test it yet, it should not be hard to put on in the water though, there are several different ways people have mounted the plate to the handle, but this way imo will keep the water pressure from pulling up the release levers, I'll post some updates when I can get it water tested
nr2041, for reference I mounted mine in the same place with the same suction cups with a 12"wide x 18" long gate banked at 30 degrees and the wave is awesome but it falls off about 25% of the time. Gonna be trimming it this weekend and making it smaller. Let me know how the 90 degree angle works for you.
got to test out the gate today, factory ballast on 03 sante plus five people, wave was super clean, pocket long enough to ride at end of surf rope and come back to boat, wave was not as big as previous setup, but previous setup was 800 lb sack in floor, two 350 lb sacks in port seats plus factory, so I am very happy and satisfied with the gate currently, I didn't get any pics today but will tomorrow, btw it did not fall off one time
This seems a lot better than the bulky plywood that will only work on one side. Were you about to make that from one cutting board?
Whered you get it?
also if that made the port side good I bet the starboard side wake is awesome. While you're posting pics can you show a little more about where you drilled the holes in the suction handle? Thanks!
Hey NR, any issue with it falling off? I tried the 8 buck HoD several times today. Works great when it stays on the boat, just need more reliability. Thinking of trying this one unless the aluminum one works well...
SeaStow 70080 Quik Grip (White/Blue) https://www.amazon.com/dp/B005HINR2I..._VU6sxb3EMJRHW
Sent from my SM-G900V using Tapatalk
Originally posted by crimedogHey NR, any issue with it falling off? I tried the 8 buck HoD several times today. Works great when it stays on the boat, just need more reliability. Thinking of trying this one unless the aluminum one works well...
