Stereo Issue - 15 G21 - No sound in bow or cockpit
  • mlsurfco
    • Oct 2015
    • 191
    • Minnesota
    • 2017 G23
    New G21 and I am getting no sound from the bow or cockpit speakers. Tower and sub are pushing out sound but thats it. I checked the zone control and that is set properly. Any other ideas?
  • MLA
    • Dec 2009
    • 1312
    • Lake Wylie NC Area
    Power light on, on all amps?
    • enzo thecat
      • Aug 2010
      • 221
      • Lake Wawasee among other places
      • 2016 G21
      Check the faults?
      2016 G21 SupeAir.
      • mlsurfco
        • Oct 2015
        • 191
        • Minnesota
        • 2017 G23
        All power lights are on? Where are the faults?
        • mlsurfco
          • Oct 2015
          • 191
          • Minnesota
          • 2017 G23
          Revision, bow is working. It's only cockpit and dash that are not working.
          • Tallredrider
            • Oct 2014
            • 1026
            • St. George, Utah
            Which amp? Do you have the stock Polk amp? I am amazed this does not happen more often because they wired the 2 cabin speakers on one side to a single channel. They did this with 2 Ohm speakers to create a 1 ohm load.
            Check the fuses you can see here. I wonder if one of them is blown.
            • MLA
              • Dec 2009
              • 1312
              If CC his holding to tradition, then bow speakers are wired to the head unit, leaving the 4 main cabin speakers on the polk 5 chnl. Since the woofer works, we know the amp works, This leaves us with an RCA cable.
              Take it with a grain of salt as im posting this under the assumption of what the audio gear is in our 2015.
              • Jfuller
                • Jun 2014
                • 27
                • Colorado / NY Finger Lakes
                • 2020 G23 Paragon 2015 G23 550 (for sale) 2010 216v (sold) 1985 2001
                I have the same issue on My 2015 G23...I have wetsounds on the tower etc, but the Polk cockpit speakers (just the 2 closest to bow, but again cockpit speakers) are not putting out any sound, the 2 cockpits to the rear are, as is the circular Polk on the top of the dash is working?????
                • Kenv
                  • Jan 2004
                  • 1070
                  • Texas
                  When this happened on my 15 G21.....the light on the amp was off...amp was bad. Cockpit speakers where not playing. They put in a new amp...boom....cockpit speakers back to normal.
                  • Guntersville230
                    • Aug 2015
                    • 419
                    • Guntersville, AL
                    • 2015 SAN 230
                    I had the same problem in my 230 but just with the bow speakers, cockpits work but were very weak....didn't want the dealer to work on it so I took to local stereo shop...they (bow speakers) weren't even wired correctly!!! Stereo guy rewired them and BAM they work perfect (not sure "what" he rewired)...I have a post in the stereo section where I talk about how disappointing it is to spend so much money on these boats and have TERRIBLE stereo work done. Additionally, it was worth having a stereo professional tune all your amps as well (if your not a stereo person) because this also made a night and day difference in my bone stock system. Just my $0.02
                    • a0128
                      • Jan 2014
                      • 423
                      • Lake Oswego, OR US
                      • 1999 Pro Air Nautique
                      Are you close to your dealer? Isn't your 2015 still under warranty? I'd be asking your dealer to remedy the issue.
                      • mlsurfco
                        • Oct 2015
                        • 191
                        • Minnesota
                        • 2017 G23
                        Must have been a wire somewhere as I pushed everything tight again then they started working.
                        And my dealer is close, but don't want to have pull it off the lake till the 25 hour service. At 13 now, so it won't be long.
                        Thanks for all the help guys.
